Create a text in Shapr3D
Hello
I would like to add a text to a design. I want to make this in Shapr3D just not straight but in a circle. Is this possible?
Currently we can’t do that in Shapr3D. I too want the same feature.
The Text tool doesn’t support circular text at the moment, however once the sketches are generated, you can use the Move / Rotate tool to rotate them to make them circular. Don’t forget to move the gizmo to the middle point of the circle, and rotate from there.
