Text Arc
This feature will solve the inability to make text in an arc shape.
This feature should be within the text add function and allow you to choose the number of degrees of the arc on which the text should follow.
Without this feature cannot easily and nicely align text in an arc shape.
This seriously slows me down in what I can produce, having to do it manually and never quite getting it right.
