The handles of the move/rotate tool should be infinitely long lines so that you can make more precise rotations depending on how far away from the center point you grab them
The handles of the move/rotate tool should be infinitely long lines so that you can make more precise rotations depending on how far you grab them from the center point.
The problem: If you want to rotate an object, you can often only do this very roughly because the handles of the move/rotate tool are too short. A minimal mouse movement results in a rotation of 10° or more. If the handles of the pan/tilt tool were infinitely long and could be gripped at any point to rotate an object, then you could make precise, small rotations by gripping the handles at a point far away from the pivot point and larger movements by gripping the handles very close to the pivot points. If the handles of the move/rotate tool were infinitely long, you could also easily align objects with other objects because you can immediately see where the handles are pointing.
Translated with DeepL.com (free version)
