Hi Team,
a general enquiry about planes and how they relate to sketches. When I need to do a sketch that’s offset say in parallel to another object, I’ll add a Construction plane, tap the object I want it parallel with and then set in the offset distance. I then do new sketch and click the plane I’ve just positioned and start drawing. Great.
However then down the road I decide that instead of the plane being 2mm offset I want it 10 mm offset. I enter the new value and the plane moves to its new location. Great … but wait … my sketch stays exactly where it was originally drawn… I don’t know about you, but I consider this to be a fault. When I attach a sketch to the plane I expect it to stay permanently linked to that plane. If I move the plane, I move the sketch… Can you advise me if this is an intentional design strategy by Shapr3D or it’s an over-sight? Could you please fix this? If you don’t then I literally have move the contents of the sketch manually which is annoying.
Regards Simon
