如何从另一个项目中导入需要的零件
最近的新项目中有使用到之前已完工的项目中设计的零件,希望能将此零件导入到新项目中直接使用,以提高效率,请问需要如何操作呢?
我认为你可以直接打开它,如果之前创建的部分那么旧,它们就不会有历史,但它应该可以正常工作。 如果没有,我建议您将零件导出为.shapr,并将其导入到新项目中,这样应该可以。
祝你好运!
I think you can just open it, the previously created parts won‘t have a history, if they‘re that old, but it should work normally. If not, I recommend you export the parts as .shapr and import them into a new project, that should work then.
Good Luck!
I just tried.it is completely correct,thank you very much,i have been trying to transfer the parts to the new project by copy and paste,like windows app,but is has not been successful.
