I have a hell of a time getting the center points of any shape except circles and ovals to activate. It only ends up selecting the whole thing if it’s a square or triangle etc. if I try to zoom in the center point stays the same size. I have made a video so you can see what I mean - https://youtu.be/RhgSkAGitds It seems the only way to move the parasolids is to select all its sides which is time consuming and terrible. This needs to be streamlined.
I would love to be able to select an entire sketch/body, press the stylus down till it "blinks’ or whatever and then be able to move it with the pen as I see fit.
The second thing is anytime I draw a sketch on a 3D surface and then extrude it, it becomes part of that body and is not its own shape. I have not found a way around that aside to make it elsewhere and then translate it over which is a HUGE workflow problem.
You can simply double tap on a sketch (not the filling, the sketches) to select the connected sketches. The points you are trying to select are just snap guides. The points with a black border are the points of the sketch. Plain white points are snap guides.
I don’t fully understand the second thing, can you elaborate a bit?
In this video, you see when I hold down on a sketch or shape, there is a little blue circle that flashes? It would be nice if that “locked in” a way to drag the shape either 2d or 3D around with the stylus when it was fully highlighted.
