Could anyone assist / show me, on how to make an UN-CENTERED-CONES?
Preferably using video mode for the assistance. Thank you.
Probably the easiest way to do this is using the Loft tool. I’m attaching a video on how to do this:
- Create two loft profiles
- Create a circle
- Using Move/Rotate/Scale create a scaled, moved copy on a different plane
- Use the Loft tool to connect the two profiles
Hope this helps
Well Done !.. thanks for your PROMPT support!
