Where: Learn the basics, step 7 out of 12.
What: Object correctly rotated after pressing the spacebar but unable to continue.
Problem: “Continue” doesn’t appear after correctly completing the task
Version: Mac OS, Version 5.870.0 (8935)
After pressing the space bar, do you get into the sketch menu / does your view automatically orientate so it is perpendicular to the face?
Make a screen shot of fullscreen and show us.
Link to video here, I can’t upload directly to the forum.
The view automatically orientates perpendicular to the face, but doesn’t progress. Apologies in advance if I’m missing something obvious here!
To be clear, you rotate the camera, then hover over bottom of the model, then press spacebar. In that order and don’t do anything else? No other movements and presses?
Try to click on the bottom instead of hovering before pressing spacebar.
Also try to rotate the camera, click on some other parts, press space. The click (not hover) on the bottom again and press spacebar.
The animation looks laggy on you machine what is your hardware?
Hi, to get assistance, please submit a support request using this link: Shapr3D Support. Make sure to include details about your device’s hardware and software specifications. Thank you!
