I frequently get into a draw mode and accidentally tap on something that takes me out of draw mode. I can then either tap a face and hit Spacebar (which zooms me waaaaaay out and shows the whole face) or I can tap on a face and draw a line. I almost always choose the second approach, which results in me having to 1. Tap on a face. 2. Draw a line. 3. CMD Z to undo the line draw that I don’t actually want, but it got me into the drawing mode without zooming me out.
I’ve used apps before that have this functionality and I assume it’s pretty common among 3D modeling apps.
I would expect this feature to include incremental line/object/face selections and draw mode changes to the undo stack so if I accidentally tap on something that removes the focus I can CMD Z and undo back to the selection state I was just in.
I would expect the following scenarios to work:
- I select a face
- I enter drawing mode
- I zoom in to a specific place on the face
- I accidentally exit drawing mode.
- I “undo” which simply re-enters drawing mode.
Or:
- I tap a corner line
- I tap several other corner lines (I intend to round them all the same amount)
- I accidentally tap outside the object and lose my selection of lines
- I “undo” which takes me back to line-selection mode with the lines I just had selected.
This is a fairly small feature request in terms of annoyance. It’s a bother, but I have my 3-step, quick workaround. This is however an area where Shapr3D failed to delight me and is noticeably inferior to other software I have used.
