Unlinking + Deleting individual sketches
I understand we can merge history, but this would be for individual sketches.
A possible workflow:
  1. Right click sketch
  2. Unlink
  3. Delete
Cleaning up the navigation tree, unlinking sketches would allow to delete them and still keep bodies and their modifications. Over longterm, big projects, this becomes a very big issue when it comes to organization and I believe software efficiency as well (resource usage).
Being able to delete a sketch and still keep bodies (and their modifications). When long term projects happen, many, many, many …, tiny minor changes happen. And what usually has to happen is either have a folder called “no touch” which consists of old sketches and simply causes worse performance and feeling. It would also allow (huge deal) moving bodies around more simpler. You move a body, modify it, now you have 2 sketches. This happens a lot in bigger projects.
Valuable organisation that would yield better productivity. Software runs slower in long term, moving bodies around takes much longer with old, linked sketches being present. It slows down the productivity by a lot, working on longer projects does happen to be quite a hassle. I love Shapr3D so I’d really appreciate if this could become a feature.
To avoid having a project full of these in the longterm:
I agree with your request, even though I personally always keep all sketches and rarely have any unnecessary ones.
However, in case you’re not aware, it is already possible to delete a sketch without losing the object — it’s just not as convenient as the way you describe.
The method is to create an unlinked copy of the object and then simply delete the sketch.
Hey, thank you.
Yeah I’m aware that copying and moving it can do it, but when it comes to many parts it’s just as tedious if not even worse (copying complex objects such as threads / gears is slow).
I do hope this feature request reaches the development team though. It’d be a great addition.
Is there any news if this would / could be implemented?
At least Merging the history of selected objects and sketches instead of either everything or nothing.
Additionally, I like to use a sketch for multiple objects, but in the process, I turn some lines into construction ones - which messes up History again. So, +1.
Is there any chance to see if this feature request is being considered / worked on?
A reply in order to bump to at least get a response?
Why aren’t any feature requests ever implemented?
I’ve just now seen a feature request for threads being open for more than 2 years.
But they added AI Visualisation.
What the f?
