Updated sketch Tool Feedback
Since the most recent updates to the UI, the sketching tool has become very problematic with how the line constraints are being applied. If I don’t specifically lock down points, sketching/adding new lines and distances will alter existing shapes.
For example, if I have something like a 3”x4” rectangle, and I add a tangent line at one that needs to be 10”, if I draw a crude line, add the 10” length → Rather than just add a 10” line 3”x4” rectangle, the rectangle will do something random like become 7.5”x4” and then there will be a 3.5” tangent line left over at one corner.
I attached a video where this sort of thing can be seen.
This is really slowly down my workflow because now I am having to lock down every point, which I know is probably good practice but even making these simple drawings is becoming a headache.
Hi @jspowers , thanks for reporting this issue! It’s not related to the new UI, most likely this bug has been present for quite a while. We’ll look into this.
Thanks @Istvan, I always appreciate the quick engagement here
