Urgent help needed / bending
Hello,
I’m working with Shapr3D since 3 days now and I need help for this sculpture.
I got a normal Zylinder and I need kinda shaped/circled blades, attached to the Zylinder.
I uploaded a picture where it shows what I need.
Thank you and regards!!
image !
New users can only put 1 picture in one post
-Use the project tool, to make a gude line on the cylinder suface
  • draw a small rectangle on the end of the guide line, then sweep
    -You can draw the sweeped cross section on a construction plane at “perp to curve at point”
I hope it help
R
A
Hello,
I tried to show in the screencast below how you can make the spiral thread around the open cylinder using the Revolve Tool:
CloudApp
I hope this is helpful.
I did some experimenting for the heck of it … I did the feature with a revolve and some tweaking …
Yes, but it’s not the same as I want. I do not want a full spiral.
Exactly!
Could you show me how to in detail.
If you do not want a full circle spiral, change the revolve angle to 180 after the revolve from the triangle.
Yes but I need this shape like Romulus369 did.
Any way to send him a message? I really need a little video about how to do this.
Sorry my first thing not work exactly.
Herea vid from the revolv
https://www.dropbox.com/s/jpv5x82hfmlrjv4/ScreenRecording_03-21-2019%2020-32-03.MP4?dl=0
Yes JST, I tried the sweep and it didn’t work for me … it might in the future if they add a constant feature to follow the path if that makes sense and I’m sure it didn’t :crazy_face:
Anyhooo I used the revolve … I used 360 degrees with 8 revolutions … I trimmed the excess of the revolve feature by using subtraction … I copied the feature with the transform tool 2 times or 120 degrees around the tube … I did tweak the face of the revolved feature using the transform tool for a better looking fit to the tube…
I did explore lofting with an array of patterns but that didn’t work all that good…
I’m sure there’s propbably a better technique but that’s how I did this one…
Allways nice to see the different ways to the finish line🙃
That’s Life in a nutshell JST!!! :+1:t2::sunglasses:
thank you everybody. I did it!
Right right on!!! Congratulations!!! Way to go!!! :+1:t2::sunglasses:
