How to calculate the weight of the model?
Input density like SOILDWORK to get weight
Currently we don’t have materials/density, but if you select a body, you will see it’s information in the bottom, so it should be a simple calculation if you know the material density.
You can measure the weight of your 3d as per the following steps:-
Step1:- Select the model for which the weight is to be determined.Enter the solidification number on the calculator.
Step2:-Multiply the number by the density of the required material.
Step3:- Divide the obtained number by 1000(1kg=1000gm).
And you have measured the weight of your 3d model.
