Why are round edges not smooth?
I noticed there has been a lot of changes in the last week. Many of which i am not a fan of. But major is one, is when I extrude, offset , fillet a circle or edge, the lines are not longer smooth they is now a double line almost? its breaks the circle or smooth edge in to many flat edges.
The model is fine. Just a visual thing. The line representing the edge is segmented until you finish the operation.
what operation? I can finish the extrude, or offset and it still remains. I just started some work on a model from last week. Now all new modeling has this very annoying feature. What is even the purpose or is this a bug in the new changes?
Sorry, you are correct. :thinking:
Go into setting and under graphics try changing tessellation setting. Probably a trade off in speed versus accuracy. The higher the part count vs system memory trade offs?
Update must have changed he setting :man_shrugging:
Bug reported (and acknowledged) in gamma, macOS/iOS.
Tessellation not quite right
Bug reports Oct 17
26.200.0 (12144)
A restart of S3D cleans up the project.
Worth checking the Graphics settings first. Tessellation Quality controls how finely curved surfaces are drawn: Very High, High (the default) or Low. On Windows there are also Resolution and Anti-Aliasing. If any of those is set low, round edges show up as flat facets. Tessellation Quality also affects mesh export, so put it back to High or Very High before exporting an STL.
To tell display from geometry, look closely at the edge. If it’s jagged but one continuous edge, the model is still a true curve and it’s only how it’s drawn. If you see separate short straight edges meeting at corners, the geometry itself has become faceted, and that’s worth a support ticket.
i never had a problem before, i have been using shapr3d for 4 years now, on the same computer. its not a graphics problem. If I zoom in I can actually see where the flat edges are created, they have their own outline. From previous post it looks like this is a know bug ???
An update reset mine to the midline setting. Changing it fixed the problem on my Win laptop. Sometimes settings automagically change.
Did you check the tesselation setting?
Do the segmentation disappear at a restart of 3SD? (Until next occurrence that is.)
Yes I did try to change the tesselation settings. The problem seem to be erratic you can see here in a test model top part is smooth bottom of same cylinder is not. I was working on a model last night, and fillet seemed ok. if I restart the program the model does seem smooth but as soon as I go to make another modification it comes back.
more examples… closer
After having paid my subscription for years now I have no intention of adding any more insight, it is not our job to make this product. The recent updates have really ruined my trust in the development of Shapr and today I figured what really is screwing my work up and I think I’m right at this, it became obvious in the end as it evolved.
It’s funny how Rhino 25 years ago had it incorporated. So thumbs down for this unfortunately.
Well, then it is the bug…
I suggest to give them some time to fix it. No software ever has not had a bug or 4. This is likely simply a visual bug. Simple test would be to print the ugly cylinder and a small mating part with a wee bit of tolerance and see what you get. Obviously it is not happening to everyone. :man_shrugging:
I have gone ahead and printed some models already. They do appear to be fine. The model once exported to my slicer appears to be normal in the slicer. So it does apppear to be bug in the software. With all the changes they have made recently its hard to tell if it is something new they have added or its not supposed to be there at all
I’m having the same issue with the recent update. Notably, it happened before I updated to the new build with the thread tool. I was away from shapr for a week and came back to it, along with the new features like offsets happening on every edge I select, the new ghost cuts, and that sort of thing. It doesn’t actually affect my prints or anything but it’s definitely odd.
