Once I get to a certain size with the scale tool, it won’t let me shrink and just says invalid body. Please explain? I’m trying to make a size chart, but I can’t now because of this.
If the model is imported as an stl or other third party file type it means it has flaws in it. Is not a solid body or has overlapping faces. I use netfab free to repair the objects before importing into S3D
It happened to me and as in your case I could make them bigger size but not let me shrink them
It is a model I made in Shapr
Hi, it seems like there is an invalid face(s) in the design. Please send us the model via support@shapr3d.com
We will look into the issue and then get back to you as soon as possible.
Ok =) thanks
