I’m trying to recreate the image below in Shapr - how would I go about creating the wires, without them looking like a rigid, solid geometry? but rather… loose and dangly
I tried tracing, but sketch line doesn’t bend and flow with the contour of the wires. Unless there is something you guys know about - that I’m not aware of regarding the sketch tool?
Any guidance appreciated - thanks
UPDATE: I figured out how to trace it. Kind of remind of the pen in Affinity Designer, tracing via nodes connecting.
Now my issue is, my 2D trace is not being allowed to become 3D?
My goal was to bring it into 3D, it would had most likely appeared blocky, I was going to convert it cylindrical with the revolve tool and call it a wrap - duplicate the rest.
I checked to make sure all the lines are connected (no openings) why am I not being allowed to lift it into the 3D realm? (See image below)
UPDATE 2:
Yes, you superbly talented, wonderful community of bastards! I found it. The problem was a very small broken line. Once I connected it - green means go!
