Wondering how to draw this sculpture or similar
A friend of mine manage to produce this sculpture.
I want to draw similar projects.
Any ideas how to draw it, is it possible.
Thank you in advance for any inputs, regards,
Cris
Material to make it was Stainless Steel 316 flat bars 100x6mm
Height 800mm….
I would suggest using loft like this:
Just copy and move/rotate the sketch to where you want to twist or turn it
Loft could work as @SM1 suggested.
Another way is to extrude and twist the ends with Move-Rotate. I did this after I subtracted two ends to give it a wedge look before I twisted.
Thank you so much for the ideas, I will start trying again with these samples you showed, really appreciate the help.
Another picture of other side.
