Wood colour adjustable and tone
Being able to adjust the tones or colour of the current wood selections would allow greater range of wood for visualisation. Currently it is a struggle to give clients better ideas of what different woods the final product will look like
Ability to adjust either the tone of the wood or colour allowing to give an idea of different woods, without the need for shapr to produce extra materials.
Having to use other render apps to get a better representation of the product design.
Is this a workflow blocker for you? Is this why you can’t use Shapr3D for work? Is this slowing you
down?
Yes it is slowing down the process as I am having to export the design out into another app for rendering , then having to go back and forth if design tweeks are required.
