WorkShop 40x40 Layout 1 Concept
Stand alone workshop concept for the 3 acre layout … I’ll add more shop tools / equipment to the concept as I doodle them … Some components have been imported from my Solidworks doodles opposed to creating them again (tool boxes) … this becomes my little library of doodled tools / equipment to be used in future projects … doodle once, use many times … a continual work in process, rarely is anything complete … never enough tools, equipment or space… :sunglasses:
Workshop floor plan 40ft x 40ft = 1,600 sq ft. … concept is to scale … I generally use a scale of 1 inch = 1 foot or .083 to 1 with larger visual projects…
An additional Work Area will be adjacent to the wall with the steps heading out … room size will be 45ft x 45ft = 2,025 sq ft. = 9 :thinking:
Shapr3D - Solidworks - Affinity Photo
Final Pic Rendered with Solidworks
Note: The snap shots from Shapr3D are absolutely fantastic!!! :+1:t2:
It’s been so long since I doodled something in Solidworks, I’ll need to learn how to use the program again!!! Good thing I still render with Solidworks here and there … Use it or lose it…:flushed:
Beautiful - thanks for sharing :slight_smile:
Thank You very much Daniel!!!:sunglasses:
Very nice! 3 acres is a lot. Where is this?
I recently moved to Wyoming and have a 50 x 50 ft. hangar. I need to do a similar design as yours, including 1 or 2 planes.
www.alpineairpark.comp
Thanks,
Thank You Tommy!!! No set location as yet … my daughter and son-in-law are looking in the Shasta, Ca area for 3 to 5 acres … Wyoming is a great place!!! Last I recall, you were in Southern, CA? The exodus continues out of California as the newbies move in!!! :joy:
I’ve certainly have found Shapr3D easy and effective in laying out floor plans and such … Congratulations on your move and enjoy designing your hangar!!! It’s endless rewarding fun for sure!!!
Fantastic job, lots of detail, what was the last image rendered in?
Thank You!!! The last image is rendered in Solidworks…
Very nice sir
Thank You Jonnie!!! :sunglasses:
