Cannot draw a spline.....?
i press the straight line point and move the point. the straight line keeps in straight line…orz||||
i cann’t make the spline…Σ(lliд゚ノ)ノ
why?
please tell me why(๑•́ ₃ •̀๑)
Don’t lift off the Pencil from the screen. Just press it and keep moving the Pencil.
Here’s a video that can help you.
Two tips:
  • press with the Apple Pencil, but don’t pick it up. make sure it has contact with the screen
  • after you press, don’t keep pushing the pencil. you need to release the pressure, but make sure to keep contact with the screen
Follow these two steps and it should work.
http://shapr3d.com/learn/draw-a-spline.html
thanks a lot!!! i drew the spline!!!。:.゚ヽ(*´∀`)ノ゚.:。
ヽ(∀゚ )人(゚∀゚)人( ゚∀)人(∀゚ )人(゚∀゚)人( ゚∀)ノ
but, i need to press on the screen very strongly that the app sense the pen pressure.
beside, the spline’s point is difficult to draw correctly follow the sketch line(sketch paper) (๑•́ ₃ •̀๑)
i need to divid the spline into more than two lines?
Currently you cannot connect two splines directly, so you have to draw a spline with one line.
It takes a little practice, we know. But you can move the control points of the spline later. That helps a lot to perfectly position the line.
You can also set the required pencil pressure in the menu in the lower right corner
