30 degree chamfer edge?
I am drawing a table with 30 degrees slope edge, but the default chamfer on edge is 45 degree, your advice please.
Draw a profile and sweep it along the table, subtract, done :+1:t2:
But problem is that the table is arc edging, I don’t see any way to build a profile and sweep it…
The Extrude tool will allow you to use any angle you like whereas a chamfer is fixed at 45°. Here’s a simple example.
Regards, Mike
Thanks Mike, appreciate your help, thanks again!!:pray:
