Here are two objects: one is the original object, and the other is its mirror image. When a two-sided chamfer is applied to both, the distance#1 on the original object does not match the distance#1 on the mirrored object. The same discrepancy occurs for the second distance.
Hi Dickson,
Does applying the chamfer before you mirror work for you? If you do, you can change the distances of the chamfer sides on both bodies at the same time in history.
hi Bob, thanks for your suggestion. But if i build the 2-sided chamfer before mirroring, i cannot see the mirrored image when editing the chamfer. In my case, i want to see how the whole body (original+mirror) will change, when editing the chamfer.
Does this help?
Hi
I think it is a bug, I forwarded your post to the Gamma team for investigation.
