A Hotkey for Mirror
Not having to click 3 buttons to mirror a piece of a sketch.
A simple Hotkey for the Mirror function so I don’t have to go backwards and then forwards through the UI to use it.
There’s nothing I can’t achieve, it’s just annoyingly inefficient. I get that there’s a search command function that helps but I’d rather have a hotkey instead of using a different feature just for this one function.
Yes, in order to mirror part of a sketch, you have to click the part, click exit sketch, click more and then click Mirror. Whereas a hotkey would be instant. It’s surprising that this is one of the few functions without hotkey.
It would also be nice if we could just map our own hotkeys.
