Ability to Mirror in Sketch mode
I see posts from a year ago that say this feature is in the process of being implemented, is it still a work in progress? I use this a lot in other CAD software and not having it is a major time hit. The symmetry function is pretty much useless in terms of saving time, since you still have to manually draw the second half on the other side of the mirror axis. The other work arounds to try and simulate this much needed basic function are a pain compared to a legitimate mirror function. Is there an ETA for when this will finally be available?
I would like this too. Having to exit sketch with the correct selection is a bit cumbersome. I use mirror all the time.
Actually, I just tried setting a keyboard shortcut M for mirror and it works directly from sketch. Problem solved.
Replaced M for move to G as in grab (Blender fanboy)
That worked! All they really needed to do was add an icon in the sketch tool menu, the functionality is already there but just no way to access it.
Thanks for the keyboard shortcut hack!!
