A non-entity entity?
Problem to solve: Ability to use an “Non-Entity” object to draw sketches upon but not extrude/combine when creating 3D objects upon the object.
Description: I 3D print from objects created in Shapr. want to have a template that represents the print bed of the printer so that I can place objects ‘on’ the bed in Shapr and start from the bed as an object but not have the object be modifiable.
Example: If i create the print bed as a solid object and then sketch a square upon its top surface and then extrude to create a box — i want the default to ‘Not combine’ the new object as an extension of the print bed.
Solution: Be able to designate an object as a reference object that is not modifiable/extendable/changeable unless made a ‘normal’ object.
Certain functions like create a plane or align would work but the object itself would be ‘locked’ and only usable as a reference.
I realize i can accomplish the above with a reference plane that is the shape of the print bed (XxY) but I want something more visual and persistent to work from and place objects so that when I export to print I don’t have to rearrange the objects on the print bed.
Solves: Workflow towards end goal of printing 3D object on a real print bed.
Locking a body and making it non-editable, but usable would be great!
