Parts bin / store / warehouse
the goal is to be able to create parts and reuse them in other projects. This would mean things like screws and assemblies.
Lets say Im designing a housing for a product. I’ll need several screws and their corresponding mating threads;
i’d like to be abel to drag and drop the screw and its threads without having to draw it and copy it. Once I draw my parts, I’m probably going to reuse them. If i could download a screw within the shapr enviroment, that would be awesome. If shapr could create one instance and copy it within the model work environment, i would expect/hope that would allow my computer/ipad to interface with less resources. This isn’t vital but might be a nice way to implement it.
to be able to use drawings in shapr without having to import. Being able to upload my generic parts and have a way to share would be rad too.
super fast design times. :slight_smile:
Its not a complete block but does add a lot of effort and time to my work.
Thanks for the suggestion! I don’t have an exact timeline for this yet, but it is definitely on our mid-term roadmap.
(I am quite sure you are aware, but to be certain: if the main things you’d import are standard screws and similar hardware, McMaster-Carr’s site is a great source with a fantastic search engine for X_T or STEP files that you could import over to Shapr3D. This of course does not help with custom-designed parts.)
Thanks for the response!
Yes, the McMaster method is essentially the one I’m currently employing. Perhaps an intergrated tool that scrapes the data from the website might be neat pair up of the two companies. This could be a really fast and seemingly accurate way to fill the metaphorcal ‘shelves’ without costing Shapr too much.
To compliment the UI that we all love so much, is ideal. The workarounds feel so at odds with how well the shapr UI works and flows. I believe a clean, integrated way to browse the internet data(models) as well as previously drawn models to ‘drag and drop’ these parts, assemblies and mechanisms into a different project would improve user productivity, significantly.
I do hope this feature gets examined and developed by your team, i think it would really add to everything that shapr is already doing very well.
