About the Feature requests category
Please post your feature requests in this category.
What is is that you can’t achieve without this feature?
pls add light in visualisation so we can add light in our object of different colours. i am making car headlights, it will be really helpful.
Please add a point to arc in drawings dimensions. I work in extrusion, the prints operators use have a height and width with tolerances. As it stands right now, the operators would have to add the arc radius to the distance from the center of the radius to the end point. Adding a point to arc would also help clean up prints were the over all height is the only dimension needed on the production line.
Here is an exp.
Parametric subassemblies with patterns that shrink or grow members based on context
The problem that this feature will solve: when a design has multiple copies of a typical subassembly, but each instance varies parametrically from other instances.
This would be a very useful and robust way to implement framing or support structures
What is it that you can’t achieve without this feature?
A good example of this would be wall framing in building construction. Wood framing members are spaced at a regular interval but shrink or grow based on wall length.
I am a Chinese user. Can you add the function of drawing space curves? For example, if I want to draw the handlebars of a Harley motorcycle, it requires several views to complete, similar to the four views required by Rhino.
