Measurements display
Would be great if we can have dimensions displayed directly on the 3d model aka Sketchup tape measure
Hi Barryd, please use the suggested format for feature requests. The template is there for a good reason: by following the suggested format, we can do a better job with delivering the features you need.
Good morning. Ok let me see if I can find this form
Where can I find this format Itsvan?
When you create a new topic in this category, it automatically shows up in the message:
