Working on a file in Shapr3D I was creating Numeral Outlines with a view to converting them into Bodies so that they will be visible in a Design.
During the process it became obvious that to obtain a balance Font adjustments would be required so alterations were made to 1; 2; 3:
4 & 5, the cause of the alterations, were commenced when the message:
Something went wrong, no changes were made
appeared and reappears with everything and anything tried, I.e., using different tools and features, closing and reopening S3D and so on.
Opening a previous Design everything seems to be normal, I was relieved on reopening the ‘Numerals’ File to find everything was back to ‘normal ‘.
Normal in this case meaning that frequently while using Sketch > Pen then switching to Sketch > Trim tapping on the portion of a Line to be removed [in the enclosed Shape of the 4 crossbar and the 5 Top bar] 8mm immediately switches back to Sketch Pen.
The workaround is to select and delete the entire Line containing the unwanted portion. On many occasions it takes several attempts to achieve the desired selection.
Having used Trim frequently the above scenario only appeared in this particular File.
Perhaps there is something wrong with my technique?
The File in question will be sent to S3D Support, named Trim Test [would be good to learn if ‘naming’ is useful in instances like this].
Very much appreciate the ‘auto(?) pop up’ Helper Videos, hopefully these will continue to expand coverage, particularly useful is that they seem only to appear when needed.
