Align one body to two different bodies?
Hi! My first post :slight_smile:
I would like to align a roof beam to the wall construction but are having a bit of a struggle to find out how I do it.
As you see on my picture below there are two differents bodies that I would like the roof beam to align to. I can only align one of the edges of the roof beam to the counstruction but I’m sure there is a way that I have not found out yet.
Any one knows how to fix this? :slight_smile:
Are you going to make a seat cut? Plumb cuts?
The way I would have done it is make a drawing plane on the side of the wall facing us. Then you could draw the rafter in the correct place without needing to align it.
Drawing planes are handy and easy to make.
I think you should create a reference body to align to, which is almost the beam itself. There is no shortcut for this case… yet :slight_smile:
Great! Thank you! Your idea solved my little problem :slight_smile:
Thank you too KPeter :slight_smile: Creative thinking is the key, thanks for you tip! :slight_smile:
