I can’t believe I’m posting this because I despise the Align tool…as @Peter_Gy and other Shapr3D staff members are aware
I think I finally figured out the secret to the Align tool…use it with a Construction Plane! Check out this video I just made. It has worked perfectly every time I align to a Construction Plane. I think this might have to do with the fact that a Construction Plane doesn’t have end or midpoints, so the Align is “agnostic” to a snapping location preference, but I’m not a Shapr3D programmer, so I’m hypothesizing at best.
I noted you “clicked” the lower side of the construction plane and the alignment of your block ended up at the top of the construction plane. Is this by default?
I’m trying to make Align useful, because it falls short of the align command in every other piece of design software I’ve used…no offense Shapr3D team.
…but I will test it when I get to work tomorrow, as I don’t have Shapr3D installed on the new PC I just built at home.
The 2nd video shows a way to align (no const plane) using a sketch plane on the body where you want to align. Note: the height of my source body is 4mm high. I offset a line 4mm down from the top of the destination body.
What is really frustrating about the second video is that the line is now there forever because if you delete it, the second object moves back to its original location, no matter if you align face to face or edge to edge. This also only works if the object aligning edges/faces are the same size; if they aren’t, it aligns them to the center point of both objects. At least using a construction plane with dissimilar sized objects, they don’t snap center point to center point, but you do have to perform multiple align commands.
And now I’m back to despising the Align tool.
How would you align the two corners in the following images?
First, you can remove the sketch line after doing the align. Both bodies stay connected.
Second, do exactly what @Xdrakosha did. Do the Align edge to edge.
Align is a great tool.
