In this case, what is the solution to align the 3 edges of my object ?
i tried with a plane but it is not possible.
I
I agree with Bob, I would select the middle face and use replace face to align it with the other 2 first. Then either drag the face the 1.8mm needed. Or use move to go that 1.8mm
It works almost perfect. in 2 years I had never use this function and getting used to it I’m sure I will get better in such situations.
