Aligning a sketch with an object?
Hi. I received simple and effective help to my queries yesterday. So here we go again.
I have an object which has a side which has a side which does not align with the X axis. I then have a sketch (imported from Sketchup as a DXF) which DOES align with the X-axis. This sketch contains a template for holes which need to be projected onto the side of the object. I need to align the side of the object with the sketch (or vice versa) so that I can use my new trick of projecting. Any ideas?
Extrude a new temp object with one side where you want your existing object and use the align tool to move your existing object to the correct location
Sorry for not replying sooner. Thank you. Everything is simple when one knows how to do it…
Cheers,
Duncan
