Hello I am a new user. Before I buy the pro version I wanted to try little. First I watched few tutorials. But when I start playing with app. I had a few problems on I pad pro.
First where are those angles? I read some comments and I found that you updated the version and to choosing the two objects will show the angles. Yes I did and for two lines it showed but with circle and line it didn’t worked. If I want to draw any line perpendicular or tangent or certain degrees to circle or any arc how can I see the angles? Or in half arc? ( the first version of app as in tutorial looks easier why did you make it harder?) thanks
Hi there, and welcome
Angles will show up between two selected, connected sketches. Sketches will have to be connected by their end points.
