- In Transform/Move, you can select sketch objects from the workspace, but not from the item list.
- Multi-body CSG operations (union, subtract, etc.) used to let you show and hide items while picking. Now you can’t.
- Sweep won’t let you change visibility while selecting either. Try to sweep a face that’s hidden by a body, along a path that’s one of the edges of the body.
- Each sketch face in Loft must have a single outline. You can’t join faces on one sketch plane.
All good points, thanks. Forwarded to our dev and QA team. I think some of these are bugs.
