Hi there, wondering if there is a way to assign the same variable to multiple items at the same time. It’s very time consuming to draw items and then manually attach it to a variable.
Thanks!
Thanks!
It’s not possible to assign a variable to multiple items in a single step.
But you can assign it to each one individually during creation.
That won’t take any longer than setting the measurements manually.
Is there a way to link sketches or bodies that are equal so that when an adjustment is made to know the others are also adjusted? I guess I could get this done by assigning the first one to a variable and then copying it.
There are several methods you can use for that, such as symmetry or equal constraints, mirroring, or assigning the same variable to multiple elements.
It would be better if you described your task more specifically — or even better, drew it — and I’ll show you how to set up such constraints using your example.
Hello @alight24,
Yes, you can assign the same variable to multiple items using batch selection or scripting, depending on your software. In Python, for example, use x = y = z = value to assign the same value to multiple variables. For UI tools, look for group assignment or property linking features to speed up the process.
Best Regards,
Julie Batson
