How to edit multiple apertures at the same time, I remember that it was possible in very early versions
Hi
You can use Expression/Variable.
Expression / Variable
How to use it? Why is it so troublesome and can’t it be as simple as before?
You CAN do it without variables. Just create the body with one hole and then copy that hole to other parts of the body. If you change the one hole’s diameter in the original sketch, all copies of the body holes will have their diameters changed.
thinks but not simple
What your are trying to do works for me.
If you wanted to do with variables it’s also pretty easy, that quick demo near the end.
