I’m using visualization tools to create framed artwork to display in a space. I’d like to assign the image of the artwork as a “skin” or a material. I’ve imported the image and modeled a frame and a surface for the image to sit on. I’ve placed the model of the frame within the model of the space, but when I try to apply the visualization tools, the images don’t appear. Is there anything I can do to make this work?
That can’t currently be done in Shapr.
You can export your model as an obj to an external render app and apply your image as a label.
I use Light Tracer Render for this. It’s only €5 a month and is very good. I’ll post some pics shortly.
Stephen! Thanks for the tip truly helpful; I’ll be experimenting soon.
Hi, Cadmio can do that too if you are using an iPad, it has projected decals since a recent update!
