Tracing or drawing shapes where curves entering and exiting nodes on a spline differ in angle is hard, consequently it takes ALOT more effort to copy existing 2D forms than necessary. Although it is probably possible to construct almost any given shape from some combination of other shapes it becomes arduous quickly.
It should be possible to change the entry and exit handles of a spline node such that they have an asymetric relationship to the node. This would be an adobe illustrator like handle to node relationship, where the use might use a modifier to change the handle from symetrical to asymetrical in both angle and strength, this would allow the user to create more complex shapes with less effort
