Converting lines to splines and fit lines to control lines ( and vice verse) will greatly increase sketch drawing ease at the artistic level, reduce frustration and save time. Since Shapr relies on sketching I think this is important to you.
Easier to create flowing detailed sketches, embossed patterns etc.
Vector drawing was a large part of my work for 16 years. I am “pretty good” at it. Drawing in vector/splines with shapr is like painting fine detail with oven mitts on. This is slowing me down in real world design application.
