I created a ‘plate’ (square, extruded to 1 inch thickness).
I created a ‘tube’ (started with a circle and extruded it to 4 inches long).
Now I want to attach one end of the tube (or cylinder) to one side of the plate.
I can set my view to top, and then move the tube until it is ‘against’ the plate. I can zoom in until I’m look at 1/2048 or even closer, to make sure that the tube is very ‘close’ to the plate.
When I do this, sometimes a drawing of this ‘assembly’ looks good, like in this example. But, in some cases, the line shown in this example drawing, isn’t there in the drawing.
Is there some other way to ‘attach’ one object to another object, where all of the lines are shown as in this drawing?
Tube-Plate_Example-1.pdf (18.6 KB)
