Basic functions are not working right on iPad
It has been a good while since working on my project. I found I was unable to alter the original parts so decided to start over. But everything I tried to get started wasn’t working. I am beginning with a simple diagonal rectangle. But it only shows one of the four lines with end point for the others. Double taping on the line or points makes no difference. I tried this several times with the same results.
I am using an iPad Pro with Apple Pencil. I restarted and updated the operating system — no difference. I check in the App Store and shapr3D shows open so I assume the program is updated. I’ve attached a pic of the screen.
Do you have section view turned on?
Istvan, first I’ve heard of it. Turning it off solve it, thanks.
