Bug: Removing a line removes parts of body (macOS)
Good morning
Odd issue here under macOS 15.2 and Shapr3D 5.77.0.
Have a body forming a metal frame and a sketch on top of it:
Now when I remove a line from the sketch, parts of the frame body gets deleted:
Even more strange when I move the sketch down:
Parts are removed from the body and parts added:
Bodies are now dependent on the sketches they were created from. If you remove a sketch line, you will lose whatever body was created using a profile defined by that sketch line. It’s all part of the parametric modeling update. If you want to disassociate the sketch from the body, you have to collapse parametric history.
