Bug when crating a drawing of a cutout
I repeatedly have an issue when I make drawings of a tube with a linear cutout. The arc on both ends of the cutout is mirrored for no reason.
In the preview of the projection angles everything is displayed as it should, but as soon as I select an angle (by pressing the + symbol) it mirrors the arcs at the end of the cutout.
Does anyone else have this bug?
Thanks for pointing out the other threads, good t know that I’m not the only one with the issue. Lets hope this is an easy fix.
Just made a quick test and don’t get this kind of problem.
Everybody is complaining but non of them want to share their project to investigate the issue :slight_smile:
I just prepared a file with one tube. The original file was larger I deleted all the other parts.
best regards
Matthias Schmidt
(attachments)
bug test drawing cutout mirrored arcs.shapr (4.67 MB)
I see where is the problem appear, will post as a bug to the S3D team just in case.
Meanwhile you can use two workarounds to eliminate this problem.
Draw arcs inside of rectangle, make them equal and tangent:
Use filet after extrude
Both approaches give correct result in drawing:
Thanks Alex, for pointing out the workaround. I’ll try that later. :+1:
