identical sketches
and you can see it worked fine for those other shapes
app version 5.480.0.5860 #ebbee53e
ipad air 5th gen ios 16.6
it’s not letting me loft these identical shapes either ![]()
wait suddenly the airfoil is lofting fine. once it gave me the error about vertices, so then i made the trailing edge a little less pointy and then lofting it gave me an error about being an invalid body, and then i tried doing the exact same thing again to take a picture of the new warning, but then it worked fine
i don’t need any help here just passing this along. feels like a bug but cant reproduce now
everything is lofting for me perfectly now. still confused as to why that first shape didn’t work ^^^^
Hello @stuartc23,
We are here to check what could be the cause here and in your other topic, just send us the Shapr3D designs in a support ticket by following the link below:
@KPeter thanks for the quick response. i’ve since deleted those projects. no support needed, just wanted to share the behaviors
earlier i was wondering if there was something inherently wrong with trying to loft this shape in your system:
but i’ve since been able to loft nearly identical shapes just fine so i think it was just a temporary glitch
