Measurements can become hard to read as a result of labels having mismatched direction, especially when trying to use fully defined sketches.
When handing labels, having the ability to quickly flip the direction of the label, and have that direction remain flipped upon saving and reloading, would make it easy to keep everything pointed in the correct direction. This could be implemented easily by extending the implementation of the “unlock” button.
A fully defined sketch with measured labels all pointed in the same direction (or centered, etc.)
No, I just think it would be nice, maybe some dev take this as an easy one ![]()
