C-drive Full: How to Change default local files drive location?
C-drive is Full: Where to find Setting to Change Default local files drive location? [Windows 10, 64-bit]
If I RE-INSTALL on a different drive, how to NOT LOSE Sharpr3D Files Sync?
Hi, thanks for reaching out! We have just updated the ticket you submitted.
To change the default save location for local files when your C: drive is full, open Windows Settings, go to System > Storage, and then select Change where new content is saved. From there, use the dropdown menus for each file type (like documents, pictures, and music) to select a different drive, such as your D: drive. You will also need to manually move existing files and applications from your C: drive to the new location.
Time to clone to a larger drive? Performance issues, looming potential crash. Might want to clean it up or you could lose it.
