Can not see double tap button
I have tried to get the 14 day free trial offer, when I tag the button to activate the offer a window opens and explains to use the double tap button. But the double tap button is so far in the top right corner I can not tap it to activate the offer. I have a iPad pro 3rd generation, I have tried to reduce the type size. It didn’t help. What can I do.
Thanks Skip
Never mind, I looked at the little picture a little closer and interrupted a little different and used the physical button at top of iPad. Worked fine then.
Hi, it’s great to know you found a way around it!
If you have any further questions, we would be here to assist.
