Can you save a template to import into other drawings?
I want to use the same template in multiple drawings, is it possible to make a template that I can import in to each drawing rather than having to draw it every time?
First day so I apologise if I’ve missed how to do it.
Unfortunately we don’t have a part library (yet).
As a workaround, you can export the part you need to .shapr or step format, and import it wgenever you need it.
Thank you for the reply, I will do that.
Am I correct that this will only work for creating new drawings? That is, I don’t see a way to import drawings into existing drawings.
When you import a model the app will offer you two options, to import it to the current workspace or to a new one.
