Cannot extrude nor loft
I have this sketch tht comes from a projection and there is no way i can extrude it or use it for loft. Then the new selection highlight just gives
Me confusion.
Can you share us your file ?
My guess is you have two separate sketches (look in Item side panel). Shapr3D allows coplanar sketches. There are several suggestions in this forum. Here is one:
Yes I will here it is. Thanks for your help
Fone v2.shapr (237.4 KB)
your sketch is not clean, some lines overlap and are not joined
see the screenshot
here the repaired sketch
Fone v2.shapr (256,9 Ko)
Thanks, i was thinking about not closed sketch but
-I thought projected sketch where always “programatically closed”
-I could not figure out how to find where interuption was located.
What is the technique to reveal interruptions? Heigh zooming, other
Anyway, merci beaucoup
